Hi Ian,
yes, the bearing consists of two halves, principially looking like this:
First you put in the right part, it is rounded, so you can put it in horizontal and then turn it vertical. Then you put in the left part, which ist prevented to fall out by the wedge mounted at the end. The wedge is used to adjust the clearance.
Regards
